I have a 2006 Pontiac Torrent - 3.4L V6 - 112,000 miles - I am the original owner. I have had a number of issues with the car over the last few months but what I am experiencing now has me stumped (I am a novice car repair person.. trying to learn more and save money). Not sure if this is significant, but in 2011 I had what the dealership told me was a blown head gasket. I found the oil to be milky / peanut buttery. It was covered by the extended warranty and the dealership replaced the head gasket. As far as I could tell everything has been good until a few months ago.
When I crank the car after it has cooled off it idles very poorly. Most mornings I crank it, wait about two or three minutes for it to idle down at which point it sputters and the engine dies. On the second crank it seems to idle higher and with a few presses of the gas pedal or more time it quiets down and runs normally. If I do not wait for it "warm up" and begin driving it feels like it loses power - I press the gas pedal and nothing happens for short periods of time until it "warms up". If I just turn the car off after it has run for a while and crank it again everything runs normally. So it seems to only be an issue when the engine is cool.
I also noticed recently that the temp guage was getting higher than it normally does (never in the red, just higher than normal). I checked the coolant level and found it was about a half gallon low. I flushed the coolant and replaced the thermostat about a month ago so that half gallon has been lost in that time frame. After refilling I have not noticed a substantial loss in coolant again, but it has only been a day or two. There are no leaks that I can see - no coolant on the garage floor or under the car in the work parking lot. After my cracked head gasket experience I checked the oil and it appears to look normal.
When the car is first cranked the exhaust is white and noticeable. It also has a different smell to it.. almost like a sweet smell or like it is burning too rich - this could be my paranoia kicking in - this could be normal given the circumstances.. i have no idea?
During this time the check engine light has come on with the following codes (I tried clearing them and they returned):
P0133 - Oxygen Sensor Circuit Slow Response Bank 1 Sensor 1
P0171 - Bank 1 System Too Lean
P0300 - Random - Multiple Misfire Detected
P1133 - Heated Oxygen Sensor Insufficient Switching Sensor 1
P1134 - Heated Oxygen Sensor Transition Time Ratio Sensor 1
P0301 - Cylinder 1 Misfire Detected
All of these errors registered more than once.. a total of 14 errors.
Thinking it was air intake / emissions related I did the following:
Replaced the air filter
Cleaned the mass airflow sensor with a purposed spray from autoparts store
Removed and cleaned the throttle body (replaced the gasket)
Changed spark plugs and wires
Replaced upper and lower 02 sensors
After doing all this the problem persists - and sadly, that is extent of my expertise
Any ideas or suggestions would be greatly appreciated.
