Hello. I swapped the engine from an 07 torrent into my 06. I did try searching but didn't help.
The original harness is in the car except the injector and cam shaft sensor harness. So the car has original harness and get was different so 06 is on it, I tried starting the car and no spark.
Ran codes and got crank position sensor and cam position sensor. I replaced the crank sensor with an 06 sensor. Going to pick up cam sensor tomorrow.
Anyone have any ideas of any other things that may be causing no spark. All grounds have been checked and rechecked and rechecked. All connections have been checked and rechecked.
Tia. Mike.
Tia. Mike.
