I'm just guessing ,how about a bad switch,wiring came loose from switch,or maybe disconnect battery for a bit to reset the software ?? ,maybe that wiring goes through some body module ?? What I would do is try to get at the two motors and see if your getting voltage at them when you hit the switch ,that would rule out bad motors.Maybe when you hit the switch someone else can try pushing out on the windows maybe they are bound up ? I 'm just guessing .. Good luck keep us posted .
