2007 torrent help
alliepopp
Hello. I have a 2007 Pontiac torrent and today I noticed that there is no sound to my turn signals and they are not working. Also my radio doesn't turn on.
did you check your fuses?
Well I didn't get a chance. When I woke up this morning my battery was dead. So now I'm wondering if the battery is low would it do that? Also on my dash it tells me my volts and says battery is normal. I got the battery tested and they said it read 375 and should be reading 650. But it was tested about 2 hours after being jumped and sitting for an hour. So would that give an accurate reading?
well either the battery is shot or you have a drain. How come whoever gave you those numbers didnt check what was wrong?
I just got vehicle and have same issues
Have you found the issue ?
both threads you added to are two years old. How about starting your own thread or tell us what you have already done to solve the issue?
