Gary Ducker
- Feb 1, 2016
HI
New to the forum and NA vehicles having just moved to Canada.
My problem started a few months ago when the temp gauge needle started moving around the gauge and having a different start point from cold. So much so it start reading overheating when the engine was stone cold !
So to start with a replaced the thermostat and disconnected the battery and it seemed to work OK. Few days later it started again. So this time i replaced the engine temp sensor. After changing it its worked fine for about a month and then today its started playing up again. So much so its move round 270 deg !!!!
At a loss what to do ! Thinking about fitting a aftermarket stand alone temp gauge as i have heard the instrument cluster is lots of $$$$$ to fix !
I thank you in advance for your help.
Gary
Gary
