2008 pontiac torrent intermittent temp sensor code
The P0116 code can be caused by the following. So when the code appears is the engine temperature below normal, if so replace the thermostat.
•Missing or stuck-open thermostat
•Bad ECT sensor
•Short or open on signal wire
•Short or open on ground wire
•Poor connections in wiring
