3.1L Firebird oil pan removal/install...?
  • Thread starter Thread starter sickofthisbird
S
sickofthisbird
What is the bolt sequence and the proper torquing of the oil pan bolts? Are there any other components that should be removed to take off the oil pan? I already know I need to jack the motor up a little, just havent looked very far into it.
Thanks in advance.
start from the center and work your way out with the tightening of the bolts and you need to remove the starter also and maybe the exhaust pipe on it,and you do have to get it very high up to get it off,but its do-able,it just takes longer to do those because of the tight space you have to work in,drive it up on a set of car ramps and that will gve you the room need to get in under it and work without having to to be too cramped on space,and place wooden blocks under where the mounts are,because if it slips it will take your have right off,good luck .
