UPDATE: The Wagner assembly was delivered Thursday, no time until today to try the install. Slave came away with no issue (had been off when I did the engine swap), the M/C was problematic. Upper (inner) nut was off the bulkhead stud with a 'snap' and no prob. The lower (outer) one wouldn't budge. Applied plenty of "Weasel Piss" to it, waited some time, a 24" Snap-On breaker bar with a six-point socket and still "no joy." I took the windy to it (half-inch drive air impact) and it rattled, then spun... breaking the stud just flush with the firewall. *^%$!!!
Spent some quality time with a Dremel tool and little cut-off disks under the dash, hollowing out that stud from inside the cab. Once the edge of the stud was exposed, a few blows with a long brass drift broke the stud from the hole in the pedal box. Replaced it with a metric Allen head cap screw of same diameter and cranked all down with nuts at the front. In essence turned a one hour job into a four hour trial... for nothing. Still will NOT go into reverse without gnashing the cogs. Linkage and cables are all snug, no slop at either end of both cables.
Now I'm flummoxed. And missing a Saturday morning! ;-)
