1996 Sunfire 2.4L
Engine Code P0300
I am assuming the cylinder ID is 1234 starting from pass. side.
I thought maybe it was a bad ign. coil, but after taking all of that apart, I see that the two coils aren't split that way (#3 and #4 are on separate coils).
Engine runs rough and shakes like it's going to jump off the engine mounts. I can pull the plug from the #3 and #4 fuel injector at the same time and I get no change. If I unplug either the #1 or #2 fuel injector plug, the engine dies.
So what ties the #3 and #4 cylinder together? What could go bad to cause just those two to die.
Again, standing in front looking at engine, it's the two cylinders on the right that are dead.
Thanks for any help you can provide!
Engine Code P0300
