3800 v6
84 2m4 ws6
I was wondering if the cylinder heads and intake manifold off a 3800 series 2 L36 would fit onto a 3800 series 1 L27? Also, what is the combustion chamber size and valve size on the series 1 to a series 2? I plan to port the cylinder heads, and possibly swap to the newer intake manifold if it will work, and maybe some higher ratio roller rocker arms. Also, what is the camshaft duration and lift for a series 1? Thanks for the help.
