#4 cylinder valve not moving
klee
2002 Montana code P0304
Looked through oil fill port a saw valve is not working.
Whats the proper fix for this problem.
Have you done a compression test? If the valve really isnt moving when cranking the engine you have a broken rocker arm or pushrod.
