Anyone ever run into an issue with your. My 461 stroker just won’t heat up. Runs 142 with a 192F stat. Tried 3 different temp gauges, two different stats. Can’t figure it out am I missing something’s here.
Have you tried renting an IR gun and checking the temperature at the thermostat housing?
Did you use a different sender with each gauge?
Are you putting anything on the sender thread?
