4l60e transmission swap, still won't move
Newby1
I recently swapped my transmission in my 2001 t/a. Once installed the car did not move! Installed second transmission and replaced all the sensors still doesn't move! Any suggestions?
You are saying the engine starts and then you put it into drive and the output yoke on the trani will not turn? Have you put it on a lift, left the driveshaft off and made sure under the car that the shifter actually moves the lever on the case?
When in neutral and on stands the wheels turn in a forward motion at a high rpm.
You sure the torque convertor is correctly installed?
Yep, I've installed several of these transmissions and ever had any problems like this
