64 Engine Swap Possibilities
  • Thread starter Thread starter tb30570
T
tb30570
_________________________________________________________________Weighting:_3_____1______1________2______3______2____2_______3
Score_Name____Dsp_____Cyl___Features_____Block_____Head_____Power___Torque__Power_Mod____Mod______Swap___Handl-_Cost_Avail-__Cool-
______________(L)__________________________________________(hp)_____(ft*lb)________Diff-____Street-___Diff-_____ing________ability__ness
________________________________________________________________________________iculty___ablility____iculty___Impact____________Factor
A_____LSJ_____2.0_____4_____Roots________Aluminum__DOHC_____205_____200_____D_____A______C________D______A______C____B_______A
____________________________Supercharger___________Aluminum
A_____LNF_____2.0_____4_____Turbo;_______Aluminum__DOHC_____265_____236_____C_____C______C________D______A______D____F_______A
____________________________Direct_________________Aluminum
____________________________Injected
A_____LD2_____2.3_____4_____Fuel_________Iron______DOHC_____150_____150_____F_____D______B________B______A______A____C_______D
____________________________Injection______________Aluminum
A_____LG0_____2.3_____4_____Fuel_________Iron______DOHC_____180_____150_____F_____D______B________B______A______A____C_______D
A_____W41_____2.3_____4_____Fuel_________Iron______DOHC_____190_____150_____F_____D______B________B______A______A____C_______D
A_____LD9_____2.4_____4_____Fuel_________Iron______DOHC_____150_____155_____F_____D______B________B______A______A____C_______D
B_____LE5_____2.4_____4_____Variable_____Aluminum__DOHC_____177_____165_____F_____B______B________F______A______C____C_______C
____________________________Valve__________________Aluminum
____________________________Timing
A_____L44_____2.8_____6_____Fuel_________Iron______OHV______140_____160_____F_____D______C________A______C______A____A_______F
____________________________Injection______________Iron
A_____LP9_____2.8_____6_____Turbo________Aluminum__DOHC_____255_____258_____C_____F______C________F______A______D____F_______A
___________________________________________________Aluminum
A_____LP9-X___2.8_____6_____Turbo________Aluminum__DOHC_____280_____258_____C_____F______C________F______A______D____F_______A
A_____LF1_____3.0_____6_____Direct_______Aluminum__DOHC_____265_____223_____C_____D______B________F______A______D____F_______B
____________________________Injected_______________Aluminum
A_____L82_____3.1_____6_____Fuel_________Iron______OHV______160_____185_____F_____D______C________A______B______A____A_______F
A_____LG8_____3.1_____6_____Fuel_________Iron______OHV______175_____195_____F_____D______C________C______B______A____A_______F
B_____LG5_____3.1_____6_____Turbo________Iron______OHV______205_____225_____D_____F______D________C______B______B____F_______C
A_____L32_____3.4_____6_____Fuel_________Iron______OHV______160_____200_____F_____D______C________A______B______A____A_______F
A_____LA1_____3.4_____6_____Fuel_________Iron______OHV______185_____210_____F_____D______C________C______B______A____A_______F
A_____LQ1_____3.4_____6_____Fuel_________Iron______DOHC_____215_____225_____D_____D______B________A______B______A____D_______C
B_____LX5_____3.5_____6_____Fuel_________Aluminum__DOHC_____215_____230_____D_____D______B________F______B______C____F_______C
A_____LY7_____3.6_____6_____Fuel_________Aluminum__DOHC_____255_____252_____C_____D______B________F______B______C____D_______B
A_____LLT_____3.6_____6_____Direct_______Aluminum__DOHC_____302_____272_____B_____D______B________F______B______D____F_______A
A_____LN3_____3.8_____6_____Fuel_________Iron______OHV______165_____220_____F_____D______C________B______D______A____A_______F
A_____L27_____3.8_____6_____Fuel_________Iron______OHV______170_____220_____F_____D______C________B______D______A____A_______F
A_____L36_____3.8_____6_____Fuel_________Iron______OHV______205_____230_____D_____D______C________C______D______A____A_______F
A_____L26 3.8_3.8_____6_____Fuel_________Iron______OHV______205_____230_____D_____D______C________B______D______A____A_______F
A_____L67_____3.8_____6_____Supercharged_Iron______OHV______240_____280_____D_____B______D________B______D______B____B_______C
___________________________________________________Iron
B_____L32_____3.8_____6_____Supercharged_Iron______OHV______260_____280_____C_____B______D________C______D______B____C_______C
A_____LD5_____3.8_____6_____Turbo________Iron______OHV______300_____245_____B_____A______D________D______D______D____F_______A
B_____L47_____4.0_____8_____Fuel_________Aluminum__DOHC_____250_____260_____C_____F______B________C______C______B____C_______D
B_____L99_____4.3_____8_____Fuel_________Iron______OHV______200_____240_____D_____C______C________C______D______B____C_______D
__________________________________________________ _______________Weighting:_3_____1______1________2_ _____3______2____2_______3
Score_Name____Dsp_____Cyl___Features_____Block____ _Head_____Power___Torque__Power_Mod____Mod______Sw ap___Handl-_Cost_Avail-__Cool-
______________(L)_________________________________ _________(hp)_____(ft*lb)________Diff-____Street-___Diff-_____ing________ability__ness
__________________________________________________ ______________________________iculty___ablility___ _iculty___Impact____________Factor
A_____LC3_____4.4_____8_____Supercharged_Aluminum__DOHC_____469_____439_____A_____F______C________F______C______F____F_______A
____________________________Variable_______________Aluminum
A_____LD8_____4.6_____8_____Fuel_________Aluminum__DOHC_____275_____300_____C_____F______B________C______C______B____B_______C
A_____L37_____4.6_____8_____Fuel_________Aluminum__DOHC_____300_____295_____B_____F______B________C______C______B____B_______C
B_____LH2_____4.6_____8_____Fuel_________Aluminum__DOHC_____320_____315_____B_____F______B________D______C______D____F_______C
A_____L26 4.9_4.9_____8_____Fuel_________Aluminum__OHV______200_____275_____D_____F______C________B______C______B____B_______D
A_____305 SB__5.0_____8_____Carbureted___Iron______OHV______300_____300_____B_____A______F________B______F______A____A_______F
A_____LS4_____5.3_____8_____Fuel_________Aluminum__OHV______300_____325_____B_____B______C________C______C______B____C_______C
A_____327 SB__5.3_____8_____Carbureted___Iron______OHV______330_____330_____B_____A______F________B______F______A____D_______C
B_____LS327___5.3_____8_____Fuel_________Aluminum__OHV______332_____433_____B_____B______C________C______C______D____F_______C
A_____LT1_____5.7_____8_____Fuel_________Iron______OHV______300_____340_____B_____A______C________C______D______C____C_______C
A_____LT4_____5.7_____8_____Fuel_________Iron______OHV______330_____340_____B_____A______C________C______D______D____D_______B
A_____350 SB__5.7_____8_____Carbureted___Iron______OHV______350_____350_____B_____A______F________B______F______A____A_______D
A_____LS1_____5.7_____8_____Fuel_________Aluminum__OHV______350_____409_____B_____A______C________C______C______C____C_______B
A_____LT5_____5.7_____8_____Fuel_________Aluminum__DOHC_____405_____385_____A_____F______B________D______C______F____F_______A
A_____LS6_____5.7_____8_____Fuel_________Aluminum__OHV______405_____464_____A_____A______C________C______C______D____F_______A
A_____L76_____6.0_____8_____Fuel_________Iron______OHV______350_____375_____B_____B______C________D______D______C____C_______C
A_____L98_____6.0_____8_____Fuel_________Iron______OHV______360_____390_____B_____B______C________D______D______C____C_______C
A_____LS2_____6.0_____8_____Fuel_________Aluminum__OHV______400_____412_____A_____A______C________C______C______D____D_______A
A_____L92_____6.2_____8_____Fuel_________Iron______OHV______403_____402_____A_____B______C________D______D______C____C_______C
A_____LS3_____6.2_____8_____Fuel_________Aluminum__OHV______430_____415_____A_____A______C________C______C______D____D_______A
A_____LS376___6.2_____8_____Fuel_________Aluminum__OHV______480_____415_____A_____B______C________C______C______D____F_______A
A_____LSA_____6.2_____8_____Roots________Aluminum__OHV______560_____550_____A_____F______D________C______C______F____F_______A
A_____LS9_____6.2_____8_____Roots________Aluminum__OHV______640_____605_____A_____F______D________C______C______F____F_______A
A_____400 SB__6.6_____8_____Carbureted___Iron______OHV______350_____400_____B_____A______F________B______F______A____C_______C
A_____LS7_____7.0_____8_____Fuel_________Aluminum__OHV______505_____440_____A_____C______C________C______C______F____F_______A
What is this supposed to be?
