Shenango
- Sep 19, 2020
Up for sale is my 1964 Tempest Custom Convertible. Showing on the odometer is 58,000 miles but the odometer doesn't work, the speedometer does work. The car has a non-original 400 CID and TH 400 trans, converted to floor shift, from a 69 Firebird. I have owned this car since 2019 and have replaced the following. Front shocks, rear springs, brake booster, MT rwl tires, alternator, water pump, fuel sending unit (dropped and flushed tank), rear light sockets, spark plugs, and PS header gasket. New before I bought it. Top and bottom ball joints, idler arm, pitman arm, drag link, tie rods and tie rod ends, carpet, Edlebrock carb, power top pump and motor, converted to disc brakes in the front. The top has some wrinkles at the sail panels but it does not leak, the rear window is plastic and very clear..
The floor pan and trunk pan are solid and have been under coated by previous owner. This car has a current Pennsylvania antique title and registration, I will let the Antique plate go with the car if purchased by a PA resident.
This is NOT a show car but a solid driver quality machine. I would rate it as a 7.5 with a rust bucket being a 1 and a trailer queen being a 10. I have $27,000 investsted. Send me a private message with a reasonable offer if interested.
Thanks, Jerry
Thanks, Jerry
