Dear forum,
My '66 Lemans has a lot of play when steering. Has anyone here had this problem?
I need some guidance on how to troubleshoot this problem methodically, since my plan is to fix it DIY.
Because the car is old, of course it was easy for the mechanic to tell me we need to rebuild the entire front end - but that production was going to cost $3,500.00! It included replacing the steering box, rag joint, upper and lower control arm bushings, idler arms, ball joints, center link, tie rods, sway bar bushings and links.
Is this job worth that price or is it doable for a lot less? I was hoping to get some guidance on which parts to check first to eliminate most of the play and then over time address the remaining items eventually.
Thank you
Thank you
