ED FARRELL
- May 22, 2015
i HAVE PRETTY MUCH DECIDED TO UPGRADE FROM A 2 BBL CARB TO A SMALL 4 BBL DURING MY REBUILD. THIS BRINGS UP SOME QUESTIONS.
WILL A STOCK 4 BBL MANIFOLD FIT ON A STOCK 67 400ci MOTOR THE MOTOR PRESENTLY IS A 2BBL 265 HP. IF SO, HAS ANYONE GOT ONE AVAILABLE? I REALLY WANT TO STAY WITH A PONTIAC MANIFOLD IF AT ALL POSSIBLE.
DURING THE REBUILD THE HEADS AND BLOCK WILL BE MILLED SLIGHTLY AND A SLIGHTLY HOTTER CAM WILL BE INSTALLED. I EXPECT THE CYLINDERS WILL BE BORED .30. WITH THIS IN MIND, WHAT SIZE CARB SHOULD I PUT IN. IT WAS SUGGESTED THAT A 650 HOLLY WOULD WORK. I DON'T WANT A DRAGSTER HERE, JUST A LITTLE STRONGER MOTOR.
ONE MORE THING. IS IT WISE TO REPLACE THE RODS WITH THE PISTONS?
THANKS IN ADVANCE FOR ANY ADVICE
ED
ED
