'67 catalina wagon
Status
Not open for further replies.
Autoguy
37k Original Miles Off Road and Garaged since 1991
Recently Purchased from family of Original owner
Back on Road 4/21/16
Numbers Matching 400 2v
Protect-O-Plate
Beautiful All Original Black Interior, Excellent Original Chrome/Stainless Trim
Solid Floors and Frame
Solid Original Body
Excellent Glass
Entire Underside of car is NEW!!!! Take it anywhere!!!
All Brand New parts:
New Tinted Windshield (Solid rust free frame under glass. Windshield guy said he hasn’t see one this rust free in a Long time)
18”/20” Ridler Wheels with Nexen Tires
Custom Bent Dual Exhaust with Magnaflow Magnapack Mufflers
Billet /Leather Steering Wheel
New Underhood Insulation Blanket
4 Wheel Disc Brake Conversion
Complete Brake System with Brackets (Only thing not new on brake system is the pedal)
Front and Rear Rotors
Front and Rear Calipers & Pads
All Brake Hoses
All Hard Brake Lines
Proportioning Valve (Specific for 4 Wheel Disc)
Master Cylinder, Power Booster
Inner and Outer Front Wheel Bearings
Rear Axle Bearings, Rear Axle Seals
Rear Pinion Seal
Rear Gear Oil drained and replaced
Universal Joints
Center Trans Mount and Outer Rubber Bushings
Fuel Tank Removed, Flushed and Sealed
Stainless Steel Fuel Line from Pump to Tank
Rubber Connecting Hoses for Fuel Line
3” Front and 2” Rear Lowering Springs
Front and Rear Nitrogen Gas Shocks
All New Front Suspension Including:
Front Sway Bar Bushings and End Links
Front Control Arms Sand Blasted and Powder coated
Front Upper Control Arm Bushings
Front Lower Control Arm Bushings
Front Upper Ball Joints
Front Lower Ball Joints
Front Idler Arm
Front Center Link
Inner Tie Rod Ends
Outer Tie Rod Ends
Tie Rod Adjusters
Any Suspension parts that were not replaced were cleaned and painted. (Control Arms, Spindles, etc.)
Underside of car completely painted
Rear Housing and front frame cleaned and painted
All New under Hood:
Belts, Hoses,Thermostat
Water Pump, Fuel Pump
Rebuilt Carb
Plugs, Wires, Cap, Rotor
New Battery
Battery Cables
Have Original Wheels, Hubcaps, Uncracked Steering Wheel, Undamaged RF Headlight Bucket/Fender Extension. Take Off Brake and Suspension Parts, etc.
I also have a Used Edelbrock 4V Aluminum Intake and Holley 600 Carb, New Chrome Valve Covers, Chrome Air Cleaner and Inline Fuel Filter Included at a Full Price Sale.
Asking $24,995.00/OBO Car is Located in Eastern PA.
Call or Text 610-390-1669 for more info. Have many more pics available. Serious buyers only, thanks!!
Status
