bwalsh67firebird400
- Jul 4, 2013
Hi I am new to this and this is my first thread. I recently bought a #'s matching 67 firebird 400 4 speed. I drove the car for about an hour (car ran great) and then filled it up with gas, about an hour later the car started running really rough and stalling. Barely able to limp it home stalled 5 times on the way home and flooded really bad.
I changed the oil, checked the points gap, replaced the points set gap, replaced plugs,wires,cap,rotor, plugs are gapped to .035. the engine now upon start up pops from the exhaust haven't driven since however i tried to adjust the qjet no change. It will pop while just idling if you accelerate not under load, ive tried adjusting timing this can make it worse or a little better. I got frustrated with the points so i installed an ignitor 2 with no change of course. I noticed that it seemed to be running out of fuel so i installed a holley red electric fuel pump and regulator last night (had it laying around for my chevelle, now I know ive got lots of fuel, set psi to about 5.5psi to 6psi. My first firebird at wits end not sure what to do, going to do a compression check today (should have done first).
ANY HELP IS GREATLY APPRECIATED!!!
Thanks.
Thanks.
