if its overheating, then the cooling components are NOT all good.
check the thermostat, radiator, and cooling fans. check electrical connections, proper operation and if all else fails, go to a mechanic for a diagnosis.
Radiator is the most important item,along with the correct amount of coolant.
You need to remember that you should add coolant first,then top off with water.
I always error on the coolant side running more than 50%.
