'70 fuel tank/sending unit seals
biggjuss
Wendell, N.C.
I've got a new tank and sending unit. Having a tough time finding all the associated seals/gaskets that I need. Any help would be great.
Thanks
neither the tank or sender came with the O ring for the sender or you are referring to something else?
www.amesperf.com carries it, part M138
Nope, no O-rings at all. Also, is there a gasket or seal for the filler neck tube where it meets the tank? That didnt come with the parts either.
Thanks!!
you either should have bought a tank with the neck already installed or you have to unsolder and resolder your current neck.
