Good afternoon,
I am having issues with my car running hot when in parades and at highway speeds. If I drive normally at 55mph and not 70mph the car runs at 185 to 190 degrees. I have checked the gap between the water pump and the seperator plate and only recently noticed that in stock configuration, the 350 motor runs a 4 blade fixed fan and a 2 core radiator.
I have access to a 4 core and I have since installed a 5 blade flex fan. Will the 4 core be enough to resolve this issue or should i look into changing the water pump pulley from an 8" to a 6.5"?
