This is an original GM bead blasted, rust free radiator support for a 1971-1972 Pontiac LeMans.
www.ebay.com
If you can weld you can use a 1970 core support and swap the upper sheet metal from your original. That opens up more options. Otherwise you have to find a good 1971 or 1972. Either will work.
