Hi,
75 pontiac 400, 6x heads, performance distributor (http://performancedistributors.com/) set up for this engine, medium comp cam, fast ez-efi fuel injection (throttle body carb style fuel injection) . Compression around 8.5 to 1. I went to set/check the timing this spring, and couldn't find the mark. Figured I hooked to the wrong wire. Nope, left front is cylinder 1. The mark showed (I'm guessing) 40 deg AFTER tdc. OK, figured the distributor wasn't tight enough last year and it was way off. As I turn it back (vacuum unhooked, 1000 rpm, it won't even hardly run as I approach 0. I set it as far ahead as I can, but then it won't start. Acts like it is 20 deg BTDC and firing before the piston gets over the top. I have to back it off to (I'm guessing because there are no marks) at least 20 deg (judging by the light gun) after TDC to get it to start. It feels and acts like the timing marks are off. I got another timing gun, and it shows the same spot. I definitely have cylinder 1. Is there any way the timing mark could be off? I guess my next step is to pull no1 plug and find TDC with the piston and see if the timing mark is right, but this just doesn't make any sense to me. I am 99% sure when I timed it before (several times, when I put in the distributor, the efi, and regular maintenance) that it was at least in the ballpark of where it was supposed to be. Even if the timing chain jumped, the crank should still align correctly and it sure wouldn't run as good as it does. I'd appreciate any help or thoughts. Thanks.
