75LemansGT
- Aug 4, 2021
Hi everyone my 75 Lemans has an automatic temperature control for the climate. It’s operated by vacuum and all of the vent controls work correctly, opening and closing the different actuators to allow air to flow in the intended directions.
The problem I have is the temperature control slider (cable) doesn’t make any changes to the position of the temp door (blend door). This door bypasses the air flow from blower around the heater core at various levels to achieve the correct climate temp. Mine stays hot all the time. The vacuum actuator that moves the blend door arm gets vacuum all the time causing the door to always flow air through the heater core. Unless I disconnect that white vacuum line.
The black vacuum line goes to the vacuum checking relay and splits into two ports. The service manual calls the device a “programmer”. It has two actuators that have two white vacuum lines from the checking relay. Port one goes to the programmer vac motor located on the bottom of the programmer assembly. Port two goes to the compensator vacuum regulator.
The temp cable is correctly adjusted as per the service manual instructions. It’s just that when it is moved from full hot to full cold and anywhere between, the vacuum actuator that moves the blend door does nothing but hold full vacuum. So hard to find any info on this. I’ll attach pics of the “programmer” from both sides.
