77 TA Fuel Pressure
BamBamm
Member
Does anyone know where to put a fuel pump pressure gauge to test the pump?
Between the pump and the carb, which means cutting the hard fuel line and adding an adapter. Or get shorter hard lines to go between the adapter.
Or just to test , get a rubber hose and clamps .
Doug in P.R. 😎
Fuel pump was bad. Pulled it off and it was rusted bad. Couldn't get the pump lever to move not even with a vice.
was the car stored outside?
