Heeelllllpppp! Does anyone have any experience with the brake proportioning valve on a 78 TA with disc front brankes??? I have just put all my brake system back together and then went on to bleed the brakes. As instructed I held in the pin on the ned of the valve and started with the nearest wheel. But I cant get any fluid to the front brakes!! I have plenty to the back (even with the pin held in, but not a drop to the front. Have plenty coming out of the master cylinder but none going through the front brake side of the valve. Also, the pin seems to have stuck in?? Are these easy to strip down??
