MidwestKITT
- Jan 15, 2012
I found a chunk of one of the front sway bar link bushings on my garage floor. I'm planning on changing them and will probably change the sway bar bushings at the same time. The link bushing seems to be urethane, so I'll use urethane. Sway bar bushings are available in rubber or urethane, so I plan to use urethane, too. Good idea?
The car has 40,000 miles on it and drives/handles OK. Should I be thinking about changing other suspension bushings? How long do these things last? I just tool around in it locally, easy driving.
Thanks
Thanks
