84 Fiero se smokes
Topher79
Can someone here give me some help on why my Fiero smoked from valve cover? Iv put a new pcv valve in it still smokes blue and there zero smoke coming from tailpipe I'm.not sure how to stop this.
The valve cover on the 2.5 is sealed. You have the PCV valve and the oil filler cap on top of the valve cover. So where do you see blue smoke coming from?
Did you check to see if the line going to the PCV valve is plugged up with carbon?
Normally the line will get plugged or the vacuum channel in the carburetor or fuel injection body will get plugged with carbon.
