86 Fiero V-6 Code 32
ChasD
I have a 86 Fiero V-6 with a code 32 reading. I have cleaned the EGR valve and replaced the tube to manifold. Check engine light comes on after 10 miles. Any ideas?
Code 32 is by far the most commonly encountered trouble code. The most common cause for this trouble code is a leak in the EGR vacuum lines. This could also be a bad EGR vacuum control selinoid , hope this helps
Thanks for your help. I will let you know what I find out
