Does anyone know if you can replace or procure the glass bulb fuse that is in the headlight motor for the 84-86's? The gears are fine (cranks up and down manually) but the motor doesn't drive. I swapped it to a known good side to eliminate the relay and power availability. There is what appears to be a bulb fuse directly behind the 3 bolt access panel that appears discolored. I haven't disassymbled beyond opening it up or tested with a multimeter yet so I am looking for an education on these light motors. The motor is in an 86 GT that is to be my sons first car once we finish the project. Any help and or information would be greatly appreciated. Thanks
