superdave
Sequence of issues..... both headlights worked fine, Turned lights off and both lights lowered but the drivers side lowered and kept running, passenger side was fine, I pressed the parking light switch and drivers motor stopped. I did this a couple of times, but drivers motor continued to run in the down position. I pressed headlight switch to have them go back up, they both did. Tried to lower headlights again, lights would not lower.
I know how to disassemble and test relays, I took the relay mounted to the headlight assembly and the relay mounted to the drivers inner fender next to headlight assembly. all contacts clean and operating. re-installed both relays and both just click.
I had to lower both headlights manually.
What am I missing?? What more do I need to check??
Thanks for any help !
