86 T/A Brake Upgrade
JAnton
I want to upgrade the stock 4 wheel disc brake system on my 1986 Trans Am. It has the stock BBS style wheels with different offsets on front and back. Does anyone have any experience in changing to a larger rotor system or other suggestions?
If you have the crosslace wheels, make sure the caliper will clear the wheel. You should be ok up to 13" rotors. Also, you can piece together a set of C5 brakes
