cypherbane139
- Sep 20, 2009
wow. it started the day i was going for an interview for a new job >_>;;;; sitting at a red light it dies, and wont crank back. after a minute of cussing and fiddling with wires and vaccum lines, i got it to start after cranking an ungodly ammount of time, i had to keep the RPM's high so it wouldnt die, anything below like 2k and i couldnt bring it back up. it sat for a few hours while at work, my friend and i figured it was the MAP sensor, so i went to grab mine, but it would start right up. so i figured it was good, drove off to my interview, and about 3 mins later it starts missing under load, but not dying completely till i let off the gas. tried a bunch of things, different ECM, ended up replacing the MAP, and the distributor (would have just replaced the module, but the distributor is under warrentee =)) no change. checked the coil right after it died and it passed all the tests. i know its not fuel, because it dumps it out the tail pipe lol... hooked a scanner to it and watched everything. CTS is fine, O2 is a little lazy but works fine. MAP, TPS, IAT all good. still dies after it gets warm. i did take a longish trip the day before, about 70 miles round trip, give or take, which is the longest ive drove it at one time. and about 5 mins before it did this crap, i put 5 bucks of midgrade in. anyone come across this or have any ideas? im pulling my hair out =P
