You can use a later getrag. Just note that the newer ones require a different bracket for the slave cylinder which can be bought from www.rodneydickman.com
Als as noted above the F40 6-speed manual used in the Pontiac G6's can be used. Although this requires mods to the shifter and the trans mounts.
