89 grand am 4-2.5 crank shaft sensor
hskrfan
I would like to know where the crank shaft sensor is located and what is the best way of replacing it since i'm doing it myself, where can i find the firing order for the spark plug wires?
On the four cylinder engine the crankshaft position sensor is behind the ignition control module which is below the intake manifold toward the rear of the engine. You can follow the spark plug wires to it.
Exploded view of the DIS assembly and related components-1987-91 2.5L engine
Doug in P.R.:cool:
