92 Sunbird standard shift cables
92Sunbird
Hopefully someone a lot smarter then me can help.
My 1992 Pontiac Sunbird LE needs to have the shifter cables replaced. The problem is that they don't make it anymore and/or I can't find them anywhere.
Car: 1992 Sunbird 2 door coupe 2.0L standard 5 speed.
I guess I see there are two transmission for this year. Isuzu and Muncie. I not sure how to tell them apart. Can you tell from VIN? Is there marking somewhere stamp on trans case?
I am need of both cables and hardware to attach to trans.
I hope someone here can help me locate the parts.
92Sunbird
Reply
Thank you for quick reply.
I went to Napa website and they show two different Part Number: BK 6202183 and 6202184. I will check with them on Monday. I just want to make sure they are the correct ones for my car.
I am assuming they are for std. trans and not an auto, but don't see info under the description. any idea how they attach? The only thing I have on my car is a loop (I am assuming that my bushing is gone and clip to sucure to pin at the transmission. I wish I had a diagram of what I need.
Anyway I will check with them tomorrow and reply what I find out. Again thanks
92Sunbird
