Are you saying the battery is dead or it cranks and wont start? If you mean it cranks and wont start you have to check if you have spark and fuel. When you move the ignition key to the run position do you hear the fuel pump come on in the back of the car? If you do, can you get a fuel pressure gauge and check the reading at the fuel rail. You can check the ignition by pulling a plug wire and trying to ground it with a insulator screw driver while cranking to see if you have spark.
