acidburn02zts
- Oct 2, 2014
Hey guys...
I'm working on a '93 sunbird... 2.0 w/ 135k on the clock. Its a neighbor's car that they picked up for $200... then was brought to me to get the bugs worked out.
I got the basic maintenance caught up... tune up + hoses, belts, t-stat, t-stat housing cap... and replaced the o2 sensor it was throwing a code for.
Car runs like a top at the moment... but as the cooling system builds pressure, the t-stat housing cap starts dripping and hissing.
The cooling fan isnt coming on as it should either... comes on when I pull codes but not when the car starts getting hot.
I thought about replacing the actual radaitor cap... thinking its stuck and not releasing pressure like it should. Not quite sure where to start on the cooling fan issue... is it a common problem?
Ideas?
Thanks guys
-Chris
Ideas?
Thanks guys
-Chris
