G
GM_Muscle
ok, heres the deal... I've installed a new head gasket on a 94 Sbird with a 2.0 OHC MPFI.. It just will not start.. Spark is dead on ! firing order is correct, Ive got fuel and good pressure every thing is connected correctly and timing is DEAD ON the marks for the cam and crank are aligned, and i have 1/4 in defelction of the belt ! it acts as if the timign is off IE: i hear firing in the intake and there is plenty of fuel vapor in the manifold !! am i off 180 onthe crank !? ive added oil to each cylinder to help as the cylinders may have dried ! it aided in starting but i have yet to have it run on all 4 or keep running ! I must be having a brain fart im missing something.... help..
thanks
Scott !!
thanks
Scott !!
