94' firebird idle problem.....Help?
  • Thread starter Thread starter kornelyb91
K
kornelyb91
I just bought a 94' firebird v6 3.4 liter from a friend the car sat around for a year then he got i to run but with a rought idle. Wen the car first starts the idle is rough and then wen it gets warmed up it's fine! i Replace the IAC, Ignition controle moduel, 3x crank sensor, and computer. I also had the injector flushed and cleaned. Before i bought it the fuel filter and tank were replaced and the lines flushed. i also cleaned all the grounds and checked the fuel press and it was fine.......so what im asking is there anyone else out there that has any idea what might be going on and if their is any way to fix it!...please!
problem fixed
After 400 in two different shop i was reading a hansens manual i thought maybe is the time so i thought for the timeing chain but i looked at my cam sensor and the wire was fryed so i replaced it and it fixed the problem!!
