94 sunbird 2.0 hesitation
  • Thread starter Thread starter com'on
C
com'on
My 94 sunbird 2.0 FI LE 5sp, has a problem. I start it in the morning and leave without letting it warm up, and everything is fine for the first block or so. After a short warmup, when I stop and then start out again under light throttle, the engine bogs down and wants to die unless I give it more gas and then it works great. Once I get going about 1800, to 2000 rpm it starts doing a little chugging, nothing serious just annoying. It doesn't do it so much if I give it gas but on a even plane (between throttle and off throttle), that is when I get a slight chugging. I think the two issues are unrelated, not sure. 2.0 FI LE 5sp. Any opinions, or referrals to posts would be appreciated. P.S. I put a bottle of Seafoam in the tank in case of bad gas. Hasn't made it through the gas yet though. Thanks
