I have a 95 Grand Am that just recently my tail lights , side marker lamps, dash lights and fog lights stop working at the same time but I do have head lamps both high and low beam. This car don't have the day time running lights option.
I did check the fuses related to these areas and they are fine; Also I do have power at these fuses. The fog lights will work if I jump wires at the relay that controls head lights and fog lights. I have a Haynes repair manual for this car and referencing the wire schematic for the exterior lights ; I believe there are no relays that control the tail lights , side marker lights or dash lights.
My only suspension at this point would be the head light and turn signal switch. I will be removing this switch later this week but in the meanwhile I am hoping to hear from some one with better insight on this issue.
Thanks
Bob
Thanks
Bob
