U
Unregistered
I have a 95 Grand Am that has a low charge. I need to put more 134a in it but it is so low the compressor will not kick on. I have looked every where for the low pressure swith to jump it to engage the clutch but I can not find it. I know where the port is but I can not find that switch. The accumalator is behind the psg side head light housing just off of the condensor and the the line runs back to the firewall. I can not find this switch on any line. My main problem is that there is a swith on the high pressure side that trips my radiator cooling fan but with little to no pressure the fan will not engage. I had to jump that switch so my car does not overheat. Can any help? Thanks.
