Need Seal (O'ring) OEM part number, size, or equivalent for 95 Sunfire 2.2 Fuel Return Pipe. This is the wide O'ring that is on the return fuel line pipe. Gonna try local dealership as I believe it comes in the fuel injector O'ring kit-but want just one o'ring for couple bucks-not the whole kit. Thus, need size, OEM part number, or equivalent. Thanks to all. Just did a head gasket with all new bolts-good idea. Replaced O-2 sensor, thermostat. Oh, and belt diagram sticker on hood of car was wrong relative to tension wheel. New plugs, wire set. Once I get the above seal-hope to run another 100k with the Iron Duke. thanks again.
