RayV
- Feb 17, 2013
I have a 95 sunfire that has not given me much trouble till recently. First off, I bought this used and the previous owner wired the fan directly to keep it running in order for it not to overheat. Is there a way to fix it so it does not need that? Secondly, it now makes a clunking noise when I accelerate. To explain, when I put it in gear and try to accelerate, it clunks and clanks, but if I rev up slightly and slowly release the clutch it does not do it. What could be causing that
? And lastly, when I go over a bump or move slowly, both forward and backwards, I can hear a popping noise from the rear tires
. I think it might be the struts but would like a more experienced opinion from the forum.
Any and all help would be greatly appreciated.
