95' sunfire
swap
currently i am doing an engine and trans swap from a 95' 2.2 w/ a 125c to a 2200 w/ a 4t40e. btw, this is my first engine swap....ever. thank goodness for a good ol hayne's manual
Welcome aboard! Thank you for signing up! This engine swap sounds interesting. What's performance going to be like when all is said and done?
honestly i think the gains will be less than 20hp since the block is mostly the same. however it has far fewer miles and obd2 plus i'll have overdrive. of course now that the trans is on its way ive learned it would actually be easier to convert to stick which is what i really wanted.
i dont really know other than it has overdrive. which is a big step up from my 3 speed. haynes manual says it is a more reliable design and takes less maintenance.
