S
smartassguy2_68
i've got a ming boggling problem..maybe you guys can help 1996 grand am 2.4 4 cyl...problem started at a stoplight..i was sitting waiting for a few fire trucks to clear the intersection and went to move on green.. when i accelerated the engine started to misfire like i had a fouled plug or dead cyl. i took it to a shop and had it diagnosed.. they told me it needed new plugs, coils, boots, module, fuel filter and inj. cleaning. replaced what was recommended and used injector cleaner no change in misfire.called shop and told them it still had misfire and they told me it was missing a "ground strap" from the coil cover. i didnt see one and everyshop i called incl. the dealer said there isnt one.. told the shop i took it to and they said they would check it and put one where the resistance was the highest. anyway..i then replaced all the injectors and the fuel pressure regulator and still had the misfire.i then replaced the cam and crank sensors along with the coil housing. that cured the misfire but when i went to test drive it it died and restarted but after a few times of it dying it wouldnt restart until the next day after it cooled down over night..i did however break a wire terminal off the wires to the starter when i replaced the crank sensor but i replaced the connector and it started ok and still starts..ive been starting and letting it run for up to 4 hrs.. it will idle and not stall until i go to drive it or "goose" the gas pedal...it seems to do this when it reaches approx. operating temp. i replaced the coolant sensor and fuel pump and battery and still have the same issue with it dying..im thinking that the o2 sensor or tps..or maybe the ecm is bad..any ideas??? im running out of ideas and patience ...
