97 grand am water pump
haberrr
I have a 1997 3.1L and I need to replace the water pump. does anybody have a good way to do it? I've heard it was fairly easy and I'm looking for a step by step way to do it.
Drain the system, remove the belt. Remove the pulley form the pump, and remove the pump. Install in the reverse order. Make sure you bleed all the air out.
