97BonnevilleSSE
- Dec 8, 2021
Weird new problem came up. It was driving normally when I came home from work and washed it. 30 minutes later I started it, and it will start and run for about 2 seconds, then dies. I tried again this morning, same issue. If I start it and then apply throttle, it will stay running at around 2K rpm. But when I let off it dies again immediately. Car normally runs fine. What could be the cause? Thanks.
